Old 01-28-2009, 11:17 PM   #323 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Lol - it's to give an idea of how one might utilize more passive cooling.
Also - check the same site for an older article on "lapping" CPU's and heat sinks. Given that your controller is going to be hand built, a good way of lessening CPU temps in computers is to "lap" the CPU's IHS surface. (Integrated heat spreader). up to 5*C drops at load can be seen, with only the CPU being done.
Using the same method on the sink itself can produce even better numbers.
Like I said - being hand built, this might be the type of attention to detail that you can put into each model?
