If you have a cover on the front I would make that absorbent so it heats up as well, maybe with ribs and a dark color, something like flat black painted steel roofing on the inside of your decorative, this would also create more some air flow on either side of that sheet because you want to suck as much heat as possible out of that radiator, not bounce it back in to it.
