Old 01-29-2009, 08:40 PM   #54 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Its alliiiive. Thanks dcb, the 12 volts did the trick with the h-bridge. It runs perfectly now. So, I made a short video of the testing. I currently just have it setup to go in and out depending on what pin I ground, so you'll see me grounding two different pins to alternate the direction the actuator travels.
