Old 01-30-2009, 01:01 PM   #13 (permalink)
MazdaMatt
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Daox - keep in mind that if you are using parallel combos, the current FROM EACH battery is divided by the number of batteries in parallel.
So where 12 batteries in series can handle X current, 12 batteries in 4 3-battery strings, could handle 3X current.
They will also have a combined series resistance that is lower. So most definately, parallel batteries are going to provide you with the capacity to push more amps.
