Old 01-31-2009, 12:06 AM   #118 (permalink)
TestDrive
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Back on page 4 of this thread, sickpuppy318 posted a BSFC Map with overlaid blue lines of constant horsepower.
Earlier today while looking for info on how to relate BMEP to Nm or ft.lb (guess I'll be revising the overlay), I came across the same Map in a TDIClub forum. The post that introduce the map had this to say -
A more useful illustration is to superimpose curves of constant power onto a BSFC map.
Each curve represents a constant horsepower developed by the engine. If you are driving on a given road with a constant grade, speed, and ambient conditions (TestDrive's emphasis), regardless of which gear you are in, it requires roughly the same amount of power to overcome aerodynamic drag, rolling resistance and driveline losses. Therefore, regardless of what gear you're in, you're riding anywhere along the same blue curve; exactly where you sit on that blue curve being only dependent on the gear you're in and therefore the RPM at which the engine is turning over.
If I take the example of operating on a certain speed such that the power is 20 HP, The lowest BSFC occurs when running at the gear that corresponds to about 1250 RPM. If I run at either a higher- or lower RPM from this point, my BSFC will increase. This is about the only point in the entire engine map where it would be disadvantageous to operate at an even higher gear if one were available (lower RPM) because of the worsening BSFC. Almost everywhere else, the lowest BSFC is achieved at the lowest possible RPM at a given power.
The Following User Says Thank You to TestDrive For This Useful Post:
khafra (06-16-2011)
