Old 02-02-2009, 01:44 PM   #78 (permalink)
jpgmtech
duramax - '05 Silverado LT
Wow! Great work on this tread. I finally found a ECM table which contains a fuel limiter for the cruise control on my diesel - it will put a hard limit on the fuel delivered while in cruise. I can set the limit for typical 60mph cruise level grade, then use the foot-feed if i need to maintain a particular speed...
Unfortunately this is pretty specialized to the Duramax diesel. The Ford Aerostar MAP sensor idea is a great one!
