Old 02-02-2009, 04:54 PM   #36 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 52.94 mpg (US)
Angry Well Son of a Monkey's Furry Behind!!
Dangit!! Just discovered that on my Honda VX, when I turn off the ignition in order to do an Engine Off Coast, the trip odo stops recording mileage ... Argh!!!
I have not yet verified if the "master odometer" also stops recording mileage...
Since I always use the trip odo for calculating my FE, and since I did a lot of EOC last tank, and since I didn't turn the ignition on until I needed to do the bump start, I probably lost about 20 miles worth of distance on my trip odo on the last tank (there are 3 times where I can coast from ~65mph down to ~55mph over 2 to 3 miles on the way down the hill to work)...
Though I knew the speedo was electronic (it goes to zero when ignition is off) I just made the naive assumption that the trip odo operated mechanically....
Guess I'm going to have to look at a better way to kill the engine (I've seen several different approaches in threads here) if I want to EOC and keep accurate track of the miles.
