Old 02-03-2009, 04:13 PM   #7 (permalink)
bennelson
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Originally Posted by MazdaMatt View Post
Hey Ben,
you may want to do this a little more scientifically.........
You're pretty good at hacki...er... fabbing things up from scratch - have you thought about adding a second spring to each rear corner in parallel with the stock ones? Do you need front and rear to be stiffer?
OK - I went and scientifically did some measurements.
With a yardstick, I measured the distance from the ground to the fender, centered on the middle of the wheel.
On the back, it was 24.5 inches from the ground to the fender. One the front, it was 24" even. No I don't know what it was before I did the electric conversion. That was something I read about in a conversion book right AFTER I yanked everything out of the car.
Those height measurements are with 72 volts in the car - six batteries, motor, etc, but no people.
When I added another 6 batteries into the car (on the floor and in the back seat) the rear sat 1.25" lower than it did without. The suspension had pretty much NO bounce at that point. I don't think I measured what the front was when I had the extra six batteries in there.
Looking under the car, the rear coil springs appear to have an interior diameter of pretty close to 4 inches. Hard to say exactly, just because it's hard to get a clean measurement with the swing arm, wheel and tire, and everything else in the way.
The length of the rear coil spring appears to be about 7.5 inches right now, loaded with the 72V system.
On the door frame, it lists vehicle weight information.
GVW=2590lbs/1175KG
GAWR FRT=1399lbs/635KG
GAWR RR=1234lbs/560KG
Max load = 688 lbs occupants and cargo
Overall, the car feels low in its suspension. It rattles a bit going over bumps, smooth roads are just fine.
The front end of the car has a bit more bounce to it than the rear.
I don't know how I would add another set of springs in the rear. There just isn't any room for something like that.
I found a web page that had pairs of basic air bags that go inside the rear springs, for what didn't sound like a lot of money.
Air Lift Air Suspension For Chevy And Chevrolet Passenger Cars
The kit is $85, but I haven't found one listed for the Metro.
I am sure I could figure out how to install these things in the springs.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
