Old 02-04-2009, 04:12 AM   #5 (permalink)
blueflame
blueflame's Avatar
While at the scooter shop 2 days ago a guy was buying a high speed pulley for his Burgman, maybe with a slightly wider performance belt the ratios would upgear considerably.... Gear up kits for the final drive should be available too? Quite simple on a CVT scooter, just 2 small shafts in the rear axle.
Larger diameter rear tyre too...
A lot of drag in that scooped body area behind the front wheel...
