Old 02-04-2009, 07:20 PM   #22 (permalink)
FastPlastic
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 17.47 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 41.74 mpg (US)
Originally Posted by 2003protege View Post
Yeah, I think what is also contributing a big deal to the double image being a problem is the size of the numbers that display uses. I plan on using a bigger display, so hopefully the double image won't interfere as much.
I have most of the stuff ordered for the mpguino/heads-up-display. Can't wait to get started.
Larger number will probably help a lot. Less overlap that way. I guess if it does end up bothering you you could pull the fighter plane trick. Have another panel just before the windshield that has a semi-reflective surface. Technically that way your not tinting the windshield. Don't know if that will get you around all the laws or not.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
