Old 02-07-2008, 07:52 AM   #1 (permalink)
Doofus McFancypants
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Altima GXE
90 day: 30.07 mpg (US)
EOC Question - what did i do wrong?
Morning all -
Yesturday i played around with EOC on the way to work - mostly on downgrades where i could get a least 0.2 miles of EOC. I have seen some of the posts on the "technique" and i followed that pretty closely.
On the way in - i waited until temp guage was at normal level. shifted to neutral - clicked key back 1 click - engine died - clicked forward 1 click so everything but the engine was ON - at end of the Coast - cluch in - shift to 5th - cluch out - engine started up and drove on. worked GREAT - i estimated that in my 12 mile commute - i have 1 to 1.5 miles of EOC i can do on the way in.
So in the afternoon - I am psyched - this will be great. 5 or so EOC's on the way home went perfect... then came the 6th one....
4 lane road - no burm ( only curb to the right) low traffic ( for once in atlanta). a solid 1/2 mile of EOC.. shift to 5th - pop cluch- RPM's come up - i push the gas - NOTHING.. it was like the engine was spinning but the car was not on. Crap - shift to 3rd ( maybe i was in wrong gear i think) - Nothing. I had to come to complete stop in the freeking lane and start with the Key. WTF?? so rest of the way home i drive like normal.. last hill until our development i try again ( coast ends with the turn onto our street - so i know if it does it again i will be off the road. i very carefully make sure i was doing the same thing i had done all the OTHER times... but the SAME THING happens .. RPM's spinning - key in correct position - but it is as if the engine is still OFF.. so i stop - key start it - and drive on.
What the heck? I do not think it is technique ( as it worked the times i did it before) engine was plenty warm (not cold start) - when the RPM's were spinning - it was over 1000 - so should have been enough to start the engine..
Anyone have any thoughts? ( recall this is a 2000 Nissan Altima - 2.4L - 5 speed)
In the meantime - i am going to reserve EOC for areas where i can pull off if this happens again ( or until i figure out what is going on)
Thanks
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
