MetroMPG -
I my first reaction was try a lower gear - and i think i did try the key while rolling.. but i may have just stopped and turned it over.
LESSON - consider the contengency plans BEFORE trying something new.
I will try again this evening. there is a strech with a long downhill and a burm incase i have issues. I will make sure i click things again to be sure i have things correct.
I have not had any fuel or spark issues before ( no issue keystarting it in the years i have had it) so i am less inclined to think it is an issue there... but with only 2 failures our of probably 15 attemps - not enough data to really tell.
I will try again ( in teh areas where i have a pull off OUT incase i need it) and recheck the KEY position - the Gearing - and even the Key starting of it happens again.
Who knows - there could me some sort of interloc that i happened to hit. I think the 2 issues were the longer of the coasting streches i have.
Thanks for the feedback and help.
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
 First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
