Old 02-08-2009, 03:11 PM   #2 (permalink)
Wingmn
Wingmn's Avatar
93 SL2 Auto - '93 SL2
90 day: 34.26 mpg (US)
09 Outlook FWD - '09 Outlook XR
90 day: 21.07 mpg (US)
I have a 93 SL2 -
On J1 of the PCU (ECU) pins 16-13 D you can use any of those. If you look at the wires in the engine bay you each injector has a pink/black wire - that is not the wire you want..
So, the 4 injector wires 16-13 on J1 of the PCU (ECU) you can tap into any of them.
I did disconnect all the injectors and measure with a DMM.
For the VSS you want to use Speed out On J2 of the PCU (ECU).
For power and ground I tapped into my cig. lighter.
Let me know if you have any other questions, our hookups should be the same.
