Old 02-09-2009, 10:19 AM   #371 (permalink)
MazdaMatt
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Paul,
generally i try to design PI control in excel... but you may have better luck with a simple circuit to test it. Doing it "quickly" in excel is best for linear systems - yours is not.
Make a circuit that has a button and does a sudden switch from 0v to 1v. Have this output go to your throttle input. Tie your scope "trigger" lead to the button and the other lead to the current sensor. Push the button, see what happens.
If you wanted to get fancy about it, make your code examine itself. Instead of reading the throttle line, read a variable. On startup, make a 1 second timer, when it expires, set your variable to the equivalent of half throttle or full throttle and set a flag. When the PI loop sees the flag is set, have it start storing its output and input values in an array. Copy that array to the computer and you can examine your system response. With that, you could even tune your P and I values in excel without trial an error.
too much? Sorry, just brainstorming solutions...
