Old 02-09-2009, 07:28 PM   #16 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
OK, here's some actual details on what I did.
I started by digging up two reversing contactors out of my box of parts I have stripped off forklifts. Forklift parts are great because they are BEEFY! (and cheap)
I cleaned up the contactors a bit, including bending back one bent terminal. They are almost pure copper, so they are very soft. You have to be careful wrenching them down.
I cut a scrap of plywood to fit under the hood and over the motor. Both contactors got screwed down to it.
Then I disconnected the M- and B- connections from the controller, and ran them to the contactors instead. That means that I had to dig through my pile of forklift parts again to get more cables to make all the connections.
The extra cables were all connected so that the contactors went to the connections on the controller, batteries, and the motor.
The two middle connections on the contactors go to that yellow Anderson connector (disconnect) which is run to inside the car, where the cables connect to two additional batteries.
That's right, I am out of space and now resorting to just placing the batteries on the floor. No passengers allowed in experimental flights anyways!
I ran a pair of control wires from the front to the batteries on the floor here. Those connect 24v of power to the contactor coils to engage "Turbo Mode"
I ran that power through a momentary-on three way switch pulled, again from my forklift parts pile. The switch is rated for up to 200 volts.
With the drive wheels jacked off the ground, I drove the wheels with the PWM controller and then flipped on Turbo Mode. The car instantly dies, because I have the Anderson connector to the extra two batteries disconnected.
Phase 1 testing looks good.
I then (with the car still jacked up) get the wheels up to speed with the PWM controller, let off the go pedal, and hit the Turbo. Instantly, the wheels get another burst of speed. I turn off the main contactor, and disengage the turbo.
Phase 2 testing passes well. No smoke from the magic box!
I then took the car out on the road, got up to speed, let off the gas, and hit the turbo. It's like it has a whole 'nuther gear - more powerful, like a low gear, yet faster like a high gear! How is this possible? Only through the magic of high-voltage!!!
As I rocket down the road, the issue of suspension and steering suddenly come to mind. Even though the car is two batteries heavier (about 150 lbs more) the suspension doesn't seem bad. I think part of that is that higher-speed roads are usually a bit better designed for smoothness.
Steering wasn't a problem either. It drove like a real car!
I have heard lots of hints on web forums about people theorizing about how to design all sorts of different types of controllers.
Well, I can tell you, it's a whole lot more fun to ACTUALLY DO IT than just talk about it.
If I end up frying my controller, I will dissect the whole thing and figure out what went wrong, and tell you all about it!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
