There is no distributor on the 1998 and newer 4 cylinder engines. The ignition system is controlled by the PCM (ECU) using data from the CMP (Camshaft position sensor) and the CKP (Crankshaft position sensor).
The CMP is located on the driver's side of the head and the CKP is directly below the crank pulley. I would start there.
