Old 02-10-2009, 12:49 AM   #28 (permalink)
2003protege
EcoModding Enthusiast
Silver Bullet - '03 Protege LX
90 day: 39.39 mpg (US)
The Golden Turd - '01 Grand Caravan Sport
90 day: 16.83 mpg (US)
OK! I made this diagram. Hopefully it will be pretty self-explanitory.
I plan on having two separate layers. The top layer will have a seven-segment number pattern in it (made out of mdf, cut on a scroll saw). The bottom layer will have holes drilled for the LEDs in a pattern that puts two LEDs under each segment of a number. The seven-segment number layer will be a bit thicker than the hole pattern layer and the whole assembly will be painted flat black in order to minimize glare. As mentioned I want to have a diffusing layer positioned in-between the hole-pattern and seven-segment layers. It might be as simple as a sheet of copy paper, but we'll see how bright these are in the daylight.
P.S. I forgot to mention that I also received my white on blue LCD screen and my binary-to-seven-segment ICs (74LS47's) in the mail today. THis project is gonna rock!
