Thread: Which CRX?
Old 02-10-2009, 03:18 AM   #8 (permalink)
seanof30306
Originally Posted by SVOboy View Post
The crx is definitely a great car for an ecomodder (I have one!!!)
Check the engine for a d15b6 stamp, that's the HF engine. I can grab a picture if you need to know where to find that.
But yeah, the drivetrain will swap into any crx from 88-91. Same is true of an D series engine from 92-00 (including the VX engine), as long as you have a 88-91 cable tranny.
What is the VX engine? Is that the lean-burn engine?
Also, were the '96 and later D-series engines OBDII? Would you just use the PCM from the later engine?
