Old 02-10-2009, 10:54 AM   #3 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Have you taken apart either the transmitter, or the receiver to see what sort of antenna is on either end?
If you are lucky the receive end will be an F connector with a stubby antenna attached, then you could extend that out . . . ..
Edit: if you always approach from the same direction you could consider a reflector behind the unit, sort of a low tech dish arrangement . . . .. .
6 speed ALH TDI
