Thread: biodiesel stove
Old 02-11-2009, 05:18 AM   #4 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Originally Posted by georges View Post
Why in the world would you go camping in the mountain at -20 below in 1 ft of snow
Long story...
I will assume that this stove will not work well if the temperature drops below 20 degrees because it will start to gel but being under pressure of at least 25 lbs, I think it will stay fluid at 20 degrees.
During the winter months here biodiesel, and all other fuels for cars, have extra additives to keep them liquid in double digit negative temperatures. But as I mentioned earlier, even at room temperature I couldn't get the stove to work properly. It is the model's fault, maybe one day I'll fool around with modding it, so that thicker fuels with higher flash points will work better. Or I'll just stick to gasoline.
Piwoslaw's Peugeot 307sw modding thread
