Old 02-07-2008, 04:31 PM   #77 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
cleaned up drive motor
I cleaned up the drive motor a bit.
Looks much nicer without all the grease on it.
Also, it looks to have a pretty normal driveshaft on it. The shaft is 7/8th" diameter with a standard channel groove. I was also able to remove the gear that was on there. Makes a neat paper-weight.
Not sure if this motor is big enough for the car motor or not though. Seems a little on the small side. It is almost 10" outside diameter, but not too long. It also looks like it has 4 brushes, whereas the big pump motor has 6.
However, this one should also be reversable, allowing me to get a Honda OR non-Honda and make the motor spin the correct direction.
As always, there are more new photos on my .Mac page, now on page 2
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
