Old 02-07-2008, 06:04 PM   #2 (permalink)
XFi
Driving NOW
XFi's Avatar
Now - '07 Accent GS
Xspire - '97 Aspire
90 day: 47.9 mpg (US)
I'm at that point right now too!
Here is my thinking-
My first steps are:
1-
Track down all info on compatible (direct swap in or limited modification) transaxle's gear ratios and final drive ratios first. R&R the complete trans if one has the desired ratio.
if this is not acceptable...go to the next step
2- Track down all compatible trans gears or final drive differentials that can be swapped into the trans from 'related' transaxles.
3- Research some racing or machine shops that could 'make' a gear set for you (I was quoted about $700-800 for this when I called around).
4- Pull out hair and scream loudly.
5- Run large diameter tires and keep your speed down.
6- Join EcoModder and search for answers in previous threads.
7- Post New thread titled 'Regearing a tranny' and hope someone has some experience with this sort of thing!
XFi
