Old 02-11-2009, 06:54 PM   #10 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
don't shave the head unless you want no end to pinging and general trouble
I am going to swap mine back to a stock head once the weather gets nicer. If you want to do any head work the best bed would be just a mild deburring/smoothing and put some stainless exhaust valves in it. A 3 or 5 angle valve job might be something to try. I am really not sure if any of that would give you much though but it would probably run smoother. And if you are going that far into the engine a crank scraper and screen windage tray would be worth adding at the same time as well as deburring the rods and bottom end.
Also I think that piston was out of a 4 cyl so the rings wont quite line up even if you could get them side by side. I will look around some and see if I can find that picture. Maybe I will get lucky
My Convertible Metro XFI Plug in Hybrid Project build log
