Old 02-12-2009, 12:22 AM   #3 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 57.68 mpg (US)
Ya, I was going to say that what you are describing sounds like lean burn... I *just* installed the Fed ECU on my '94 Honda VX (It's originally a Cali model, and did not come with the lean burn feature from the factory, but a swap of the O2 sensor and the ECU with Fec VX parts enabled it), and I can definitely feel the change between normal and lean burn... That hesitation is the tell-tale...
Also just received the MPGuino, which I hope to get installed some time in the next month or so... as MetroMPG says, that should be able to tell me when I'm burning lean as well (via a jump in MPG, I would expect).
