Old 02-13-2009, 01:46 PM   #10 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
it sounds like you might have the thermostat set higher then you need it if you are able to turn your hot water down on your shower, turning that temp down will save money as it's not getting as hot, it will also protect your kid from getting burned by to hot of water.
there are alot of water heater timers out there, mine runs on a 24 hour program so it treats every day of the week exactly the same, there are 7 day timers that let you change the heating times each day of the week, the most expensive timer I've seen has a temp sensor on the water heater and so it over rides the stock thermostat and lets it simply be a back up, that timer I think can both be programed and appeared to be self learning to throttle back by learning your use patterns.
