Old 02-14-2009, 08:41 AM   #24 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
From what I've read, which isn't a TON, the target RPM should be anywhere from 1700 to 3400 rpm. However, in my case I can simply use a different size pulley if the motor is too slow which will likely be the case (vs it being too fast).
