Old 02-14-2009, 11:25 PM   #18 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by JRK5150 View Post
Ok, I've tried neutral coasting a couple of times recently. Mostly to red lights, always at a fairly slow speed. So far so good! =) I haven't done it enough to see any mpg increase, but everything seems just fine mechanically. I think I'll incorporate more neutral coasting into my driving style and see if I notice better mileage over a period of time.
If you need to brake, try dropping it a gear (rev-match if you can) and you'll end-up with a lot less on the fuel consumption (DFCO). Let the compression do the work...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
