Yes, they go into the ecu. I have run into another problem in that the injector pins are the 12v side of the signal. I really didn't want to go through the firewall but now it looks like I will need to in order to get the correct wire. There are about 5 different pinouts for the 6th generation of civics, if you need a different one than what I posted, let me know.
