Originally Posted by rmccomiskie
I'd still like to use the ECU signal. I know now that the MPGuino is working correctly and that I'll have to dig into the code to resolve the issues.
I'd be very interested to hear if you find a way to use the ECU fuel consumption signal. I'd like to adapt the
MPGuino to a VW Passat TDI which has no injector signal available (it's a rotary pump injection system), but it
does have an ECU fuel consumption signal similar to yours.
Good luck and keep us posted!
