Old 02-17-2009, 11:35 AM   #24 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I totally forgot about this, but I did swap springs on the Paseo. So, I have the stock set laying around. You should measure your springs up and we'll see how they compare and if they'll fit. The Paseo weighs in at just a hair over 2000 lbs, so they should be a little bit heavier.
Edit: If you can, measure the OD and ID of the spring as best you can. Also measure the diameter of the spring rod itself. That plus the number of windings is a good rough indication of strength.
