Old 02-17-2009, 06:39 PM   #72 (permalink)
davidgrey50
Cogito Ergo Ecomod
davidgrey50's Avatar
Dobbin - '04 Dakota 3.7 V6 A/T
Two openings might work even better, as you could put a different rate spring on each for a two-stage blocking - flap 1 with a weak spring to close one opening for fairly fast, and flap 2 with a stronger spring to close the other opening for way fast. Of course, a flap could cover only part of a grille opening.
