Old 02-08-2008, 12:31 PM   #15 (permalink)
brucepick
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.92 mpg (US)
Originally Posted by WaxyChicken View Post
The Patient: SkuttleButt, a 96 Ford Taurus sedan.
The Ailment: Leaking upper transmission line (right at the nut)...
OK, I think we're pretty much agreed that $-wise it makes sense to fix the leaky thing. Question is, how?
Considering the leaky fitting you'll probably need a new line. However I've seen shops cut the bad line a short distance from the bad end and splice on a new end. Saves you from having to find a source for the complete line and pay the price - just the cost of the short bit you're replacing.
Also if you want to have another go at it, get a wrench that will really get in there and see if you can tighten it. Maybe you can use a short stubby wrench or a crow's foot "socket" on a 3/8" drive set. I made a stubby wrench by cutting off part of a regular wrench handle. For this job you probably need a flare nut wrench, get a cheap set and shorten the handle if needed. Dremel with a reinforced grinding wheel did that job nicely for me. Cheapy no-name "Dremel" grinder has turned out to be one of the most useful tools I ever bought.
There are also wrenches with heads bent at a sharper angle than usual. I'd think you or a friend could make one of these too. Might need some heat but probably could be done.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
