The upsolute was about all that was available in 2001. The car is rated to tow 2000 lbs, so a 1500 lb car ( there is no trailer, the car was towed on a tow bar) should be fine.
But no doubt the combination of the two shorten the turbo's life. I still have the chip, but don't tow anymore. I expect the new turbo to last longer.
The fuel pumps never had a problem until they took the sulfer out of the fuel as it lubricated the pump. Clean Biodesiel is a very good lubricant, and can take the place of sulfer. I run 10% bio just to lub the pump.
Others ran into problems when using Biodesiel that still had Lye or methane in it, both are very corrosive and can destroy the fuel system.
