Old 02-19-2009, 08:08 PM   #3 (permalink)
brucepick
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
TPS - - - - MPG
LBN - - - - aFE
TPS is critical to helping the car stay in lean burn. Has to be <20 to go in. Anything over 31, and it will go out of LB.
aFE is Average Fuel Economy for the current trip. It's an X-Gauge setting based on the avg mpg for current trip. The manual tells how to set up that one.
LBN is Lean Burn, for my Civic HX. Below is the setup for that gauge. I got the setup from a post by MrChoi on another board.
Use the code below to monitor lean burn with the Scan Gauge II.
To Monitor Lean Burn, type in:
TXD 686AF10115
RXF 044105150000
RXD 2808
MTH 000100020000
NAM LBN
and save.
If the value for LBN = 0 you are in lean burn.
If the value is higher than zero, you are not in lean burn.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
