Old 02-20-2009, 09:26 PM   #5 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Ok, here's another idea. Are there any programmable thermostats that allow you to have both the A/C and heat activated at the same time? I was thinking have one heater, set on low setting, (~650 watts), be always on, UNLESS, the A/C triggers, flipping a DP relay, shutting it off, until the A/C portion clicked off, and restarted the heater...
Meanwhile, have the other heater, which has 1k and 1.5k watt settings, triggered via the heating portion. I figure setting the A/C portion for 62F, and the heat for 60F, to keep everything tightly controlled.
All of this would be completely independent of my central system, which is now shut off at the breaker. (It just flat out takes too much power, to the tune of 9kw, AND blows cold air for the first minute).
Thus far, manually triggering my 2 space heaters in an attempt to hold 60F has resulted in my power bill following the trend of the temperatures... Downward.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
