Old 02-22-2009, 11:48 AM   #12 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Originally Posted by jjackstone View Post
Actually if I recall, from MetroMPG's and other's posts, the alternator disconnect has been showing about a ten percent gain in overall FE. Please correct me if I'm wrong.
MetroMPG's car is so optimized he could go on a diet and loose 5 pounds and get a 10% improvement. His results in magnitude of improvement are not typical gains for an average car.
The TE generators do work but as has been stated are highly inefficient-- unless a newer technology has been released, they are generally between 3-5% efficient.
Doesn't matter what gear the vehicle is in, just the temperature differential between the "cold" side and the "hot " side of the junction.
Driving in first at high rpm is the best way to heat up the exhaust. The car is burning the most fuel it can in a given time and the engine is under the least load, hence the pistons are extracting the least power from the combustion gases and the hotter the exhaust gases.
Actually winding a car up in neutral at full throttle would be better for heating the exhaust but you would probably throw a rod.
