I wonder how the selector for reverse differs from those for 1st and 2nd? It may be possible that you were somehow trying to select two gears at once. That's an excellent way to lock up a transmission solid, for as long as both gears are selected. In fact, it's an old trick to be able to remove nuts and bolts from the guts of a transmission without the gears and such spinning on you...
-soD
