Old 02-24-2009, 02:30 AM   #19 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Keep in mind the alternator is only roughly 50% efficient. So, in order to generate 600W, you need to generate 1.6hp.
Good catch. So that would raise the bar to 34 HP. However it forces the alternator to operate in its lower efficiency range which would reduce the net savings.
