Old 11-28-2007, 12:20 AM   #6 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
Better late than never, the Camry results:
Conditions were pretty ideal:
Temp: 25 C / Wind: 2 km/h SSE
Test approach was A-B-A, where...
A = no mods in place;
B = rear wheel skirts plus "fairing" behind OEM mud flap where the lower aft edge of the skirt was attached
(note: pic taken the next day after tape had been applied/removed several times already - it was a smoother installation for the test runs.)
- 3 bi-directional runs (6 one-way runs in each direction) for each of A,B,A
- Speed was 95 km/h, cruise control set once, cancelled by brake between runs, (flat, deserted road, little to no wind, no traffic in my lane; infrequent oncoming cars)
A average = 45.9 mpg (US)
B average = 46.3 mpg (US) - 0.7% increase over A
This was on a 2007 Camry hybrid.
But here's the problem: while the average of the six bi-directional A runs is less than the B runs, there was a big difference between the average of the first and second set of A runs:
In fact the average of only the 2nd set of A runs is bigger than the average of the B runs.
If you look at the Corolla test, you'll see something similar: the average of the 2nd set of A runs is higher than the first set (though not higher than the B runs).
All of which suggests to me that:
1) in both cases, the drivetrain was probably still warming up (making the car more efficient) while I was doing the runs. This skewed the results.
I had driven each car for about 25 minutes & 25 km before starting the runs.
2) if #1 is true, then if I had done a 2nd set of B runs after the 2nd set of A runs, the difference between the A & B averages likely would have been greater still.
Unfortunately, the only way to know this for sure would have been to do another set of B runs, and I didn't.
In conclusion, my testing bites.
Also, testing for small differences is difficult & time consuming.
And I need to drive much further to ensure a car is fully warmed up next time I try a test.
