Motor_control: Don't worry, I have some thermal grease in the garage. I was just testing it to see if there were any gaps when bolted together. Do you know if the inductor that you suggested on the AVcc pin will cause an inductive kick when power is cut to the ATMega8? Do I need a freewheel diode there, or is it OK?
Thanks Matt!
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
