Old 02-24-2009, 11:03 PM   #446 (permalink)
NiHaoMike
Originally Posted by MazdaMatt View Post
NiHaoMike, I was not implying that a flyback transformer should be used to power the vehicle. I asked the electrical engineer about replacing the diodes with mosfets and she told me to look up how that is done in a flyback transformer circuit for an example of how it should be done with a motor.
Paul, there may be mosfet drivers that have built-in flyback control. I will research further. This would be sweet.
A DC motor controller is actually much more like a buck converter than a flyback converter. The commutation diodes provide a path for the induced current to flow. The controller will work as a boost converter during regen, however, so it would be necessary to also use commutation diodes on the high side.
The circuits used to provide a path for leakage inductance in flyback converters are not practical for use in motor controllers. A PC power supply I have that is based on a flyback topology has a capacitor from the drain of the power MOSFET going to a pair of fast recovery rectifiers, with an inductor in the low side to limit peak current when the MOSFET turns on. To use the same design in a motor controller would require a large, expensive capacitor with a high peak current rating.
Synchronous rectification actually is generally not worth it at high voltages. But since a DC motor controller already has the correct topology for it, it wouldn't cost much to include it.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
