Originally Posted by AndrewJ
So, there may be problems....
"virtually all engines utilizing Atkinson cycle technology are used in conjunction with superchargers or electric motors (hybrids). This is due to detonation limited low speed maximum torque deficiencies associated with late intake valve closings utilized in conventional Atkinson Cycle Engines."
Can't seem to find any difinitive word on the HF's particular cycle (Atkinson/Otto)
This doesn't make sense to me. Why would you have detonation problems at low rpm without a supercharger, but with a supercharger you wouldn't? When you apply higher cylinder pressures is usually when you see more problems with detonation.
I can definitly see why the electric motor works, but why supercharger?
