Diodes soldered!
I got the diodes soldered to the PCB. The mosfets are a little tougher, because they need a couple resistors soldered too. So, there will be some drilling required.
Front view
Back view!
Good enough for government work.
The careful observer will notice that version 0.1 will be 144v 500amp (50 amps per diode).
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
