Old 02-26-2009, 08:13 AM   #453 (permalink)
MazdaMatt
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Paul, are those fets soldered through the board, or flat onto it? If flat, i'd be concerned about re-aligning them when you screw then into the heat spreader causing some pulling on the solder joints. pulling + vibration -> crack -> poof.
