Old 02-26-2009, 02:05 PM   #7 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Neat.
I think the fist gen. Insight 1.0 litre engine had an offset crank as well. (Plus roller rockers and other stuff.)
Yup: InsightCentral.net - Encyclopedia - Honda Insight Offset Cylinder
The engine block has a unique, offset cylinder design in which the bore center is offset 14mm from the crank center. Maximum combustion pressure occurs at a point where the connecting rod is straight up and down in the cylinder. In this position there is zero lateral force so friction and piston slap are reduced.
As a result of the offset construction, the combustion pressure is used more efficiently since the rod is near it maximum leverage point with the crankshaft.
