I've assumed all along that the ECU fuel flow signal is an exact representation of the injector signal but narrower so all 6 injector pulses can be included within the same time period. Given that it looks like the ECU pulses are 0.123 times the injector pulse width, I expect the settling time to be similarly scaled.
For an injector settling time of 500uS, the ECU settling time would be 0.123 * 500uS = 61.5uS; Injector Delay uS = ~62uS.
I'm going to use 62uS unless experimentation disproves my theory. Keep in mind that the 500uS injector delay is simply an assumed value based on experience across a lot of different injectors. It may or may not be correct for an Audi injector.
These posts give some background information on the injector settling time issue:
MPGuino release one workspace
