Old 02-27-2009, 10:37 PM   #19 (permalink)
energy0uth
cheap yet balla
buster - '97 Grand Cherokee LTD
Send a message via AIM to energy0uth
Originally Posted by alacreta11 View Post
HI
You are at the same point of replacing the brake rotor that I am with my 1992 Geo.
You say that your friend told you how to remove the hub. Could you tell me?
Is the hub nut keyed? Does it have right or left handed threads? I am replacing the left
( passenger side) brake rotor and pads. Also could you possibly know the exact part number? Thank you for your help.
you should not have to pull the hub to do your rotors unless I missed something by not reading above.
if you do just get necessary tools and if the rotor won't come off use a rubber mallet and a large pry bar. google any problems someone else has probably done this already
