Below is the
MPGuino installed in my '96 Passat TDI:
This pic was taken in the early stages of calibration, so its reading a bit optimistic
Many thanks to dcb and rmccomiskie for their helpful posts on this subject.
What I ended up doing is tapping into the ECU fuel consumption signal as a substitute for the lack of a 12V injector lead in a TDI. The ECU fuel consumption signal is a "negative pulse" which requires a minor change to the
MPGuino code:
Change:
attachInterrupt(0, processInjOpen, FALLING);
attachInterrupt(1, processInjClosed, RISING);
To:
attachInterrupt(0, processInjOpen, RISING);
attachInterrupt(1, processInjClosed, FALLING);
Again, thanks to rmccomiskie and dcb for figuring this out - it would have taken me a whole lot longer (if ever) without their help.
I tapped the VSS and fuel consumption signals at the instrument cluster plug. A Bentley manual is very handy for identifying the wire #s. On my Passat, it was wire 26 and 27 IIRC. Green and white wires spliced in below:
I procured an ashtray from a salvage yard Passat and cut a hole in it to make a somewhat stock appearing enclosure. Since the cigarette lighter was nearby, I tapped the constant 12V here.
With about 50 miles on the MPGuino, it looks like it's going to read fairly accurately. I had a 98 Jetta TDI with
scangauge and the instant MPG readings on the MPGuino look fairly consistent with what I used to see with
Scangauge - i.e. Idle shows ~0.17 GPH, coasting in gear 0 GPH, steady 60 MPH cruising shows 45-50 mpg on flat ground, 5-20 MPG while accelerating or climbing hills.
I'll post back with my calibration settings when I get a few more test miles racked up.
