Originally Posted by alohaspirit
How accurate is this list?
Id read through a lot of it and it seems a little up for contention.
your answer:
Originally Posted by Daox
Well, its definitly no Bible. But, its a heck of a lot better than nothing. Most of my info that I wasn't sure about I double checked against multipule sites. That being said I have used info from tons of different sites since I pulled most of the info from google. Frontal area is definitly estimated, so this really is a 'best guess'. No offense, I'm not going to go through and source every piece of info. The numbers will vary, but not by that much. You can see generally where your car sits against the pool of cars on the list. So, when someone comes on the site and says they have a frontal area of 19ft^2 you can know that is pretty small.
So, basically its as good as its probably going to get.
Thanks for the added info NachtRitter and Neil. It will be added.
