Old 03-01-2009, 01:25 PM   #7 (permalink)
jamesqf
I'm sure you already know the SG doesn't factor lean burn into its MPG calcs, right? The Guino does, however.
I don't really know much about the internals of either, but was under the impression that they apply various algorithms to estimate fuel consumption from the OBDI-accessible info, while the Honda OEM display computes fuel consumption by adding up the amount of fuel the ECU tells the injectors to deliver. A lot more accurate, but hard to do unless you're the one writing the ECU code.
